Thread: Intake Gaskets
Old 03-29-2013, 06:55 PM
tcrist tcrist is offline
Default Intake Gaskets
I am sure that this has bee beaten to death but for the life of me I can't seem to find any info.
351W, GTP-40 heads, Edelbrock intake.
What is the correct intake gasket. Mine seem to keep leaking if I hit it hard at all.
Hit it fairly hard and then on deceleration exhaust started crackeling and did not want to idle.
If I spray starting fluid on the sides of the intake the rpm's raise so I know that it is leaking. More around 7 & 8 but a bit around 2 & 3 also.
Side intake gaskets only, front and rear are holding up. Have had two sets of FelPro on it with the same issue. Torque was correct and checked after a couple of heat cycles.
I am starting to think that maybe the angle between the intake and the heads are not correct.
Any ideas?
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
