Originally Posted by Eljaro
The bolts on the Melling pumps as they come from the factory may not be tightened as should so I would check that.I also removed the aluminum tag with the model code.
That's surprising to hear from a KC motor. Checking a new pump or blueprinting it is SOP with good builders.
