  #34 (permalink)
Old 03-30-2013, 01:47 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
KC didnīt supply the oilpump since this was a short block. Pump came out of the box and I installed it myself. Should have checked the bolts beforehand.
Anyway, one place oil pressure can leak out is the oil pump and if you have an oil filter take off and did not seal it right or with too much RTV sealant, pressure can push its way out somewhere it should not.
Just one place Mike should have a look.
Nothing sounds better than a Cobra in a Tunnel !
