Old 03-31-2013, 06:35 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by cobracosta View Post
"..........So the question is if you have an aftermarket cam would that cause you to retard your timing more ( from 12' btdc to 20'btdc)..........."[/img][/url]
when going from 12 degrees BTDC to 20 degrees BTDC you are advancing your timing, not retarding it.
terminology aside, yes. A cam with more duration will generally need more timing (advanced) to completely burn the intake mixture, especially at idle
Z.
'65 K code Mustang
'66 Galaxie 500
