Old 04-01-2013, 08:17 AM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Luce wrote:
"Well, per the everything I read, with a roller cam, you should use a steel gear"
With a (FORGED STEEL) roller cam. you should use a steel gear.
Eg: If its a comp cam part # _ _- _ _ _-9 . The -9 indicates forged steel roller cam, which in turn suggest you use steel gear.
Was your cam made from forged steel or cast iron?
