Old 04-01-2013, 06:58 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default DANGER Will Robinson
BE CAREFUL
I used Weldwood contact cement on my first install and it failed. Seems the heat of the sun shining on the vinyl will melt the contact cement or make it soft enough to lose its grip.
I then went to a Hi-Temp contact cement from an upholstery supplier. Much better but even that tends to soften slightly.
Sun on the back wall will not be your friend. Make sure you use Hi Temp
Paul
www.65shlb.com
www.prdcrrct.com
