fms crate 351 was rated for 385hp with a vic jr intake and everything else similar, so i would say your's is expected. i had the fms 351 and installed afr185 heads, advanced the cam and put on the rpm air gap with 750 cfm carb and liked the results. also changed out the 40# flywheel/clutch for a 18# setup, that made a big difference. keep in mind when you use a dual plane intake, you are really using half a carb on each cylinder instead of the full rated carb cfm.
