Old 04-04-2013, 02:31 PM
sdonnel sdonnel is offline
Cobra Make, Engine: Building Mk4 Sold - Factory Five Mk. 3.1
I've only done the output seal. Simply pry it out and make sure everything is clean. Use a socket type of device to align the flange with the bore and give it a good hit with a mallet. I did mine with the trans in the car and it took longer to pull the driveshaft than it did to change the seal. Hope this helps.
Scott
