Old 03-13-2002, 07:49 PM
Cobra 29 Cobra 29 is offline
Cobra Make, Engine: ERA 427SC FMS 351W
Default Eliminating 2nd Heater Hose Outlet on Water Pump
I have a 351W without a heater (and no plans to add one). I noticed the second heater hose on the water pump is plugged with a short piece of hose and metal bolt. Not liking points of failure and desiring the maximum cooling for Florida, should I run a heater hose from this second hose outlet to the manifold? Would this increase the cooling or divert water flow away from the radiator? The other heater hose outlet on the pump is the thermostat bypass hose.
