Old 04-08-2013, 05:15 PM
cobracosta cobracosta is offline
Cobra Make, Engine: classic roadster, 302, dual carbs
yep I just replaced them I think I should not do the extra 3/4 turn once I get the pushrod w/o slop. I noticed when I was replacing the lifters they were all original mighty loose. you could wiggle the rockerarm....... I was thinking of doing a leak down test after I adjust the valves to see if its the valve partially open. I have a compression tester not sure i Have the attachment to put compressed air in the cylinder though.
