Originally Posted by strictlypersonl
Yes.
A 331 cid/400 bhp engine will probably have peak power at 6500 rpm and be limited to 7000rpm. I would gear it to have peak power in 4th gear at 130-140 mph. That translates to a 3.54:1 dif ratio.
That is what we went for - peak @ 6300.
With a 351, expect 2350-2500lbs. A bit more if you put a roll cage in. Not many places to remove weight.
The car was 2440 with the 351. New configuration is aluminum 302, light T5, light clutch assy, alum bell housing, and ERA rear. Shooting for 2300 maybe less. We Got 150 out of the trans and rear if the rear comes in @ -50.
The 351 was 425. Unsure how much we will improve here, but we should get some.
Will get a little out of the screen and fixed alum drivers seat.
