  #26 (permalink)
Old 04-09-2013, 10:38 PM
tkb289's Avatar
tkb289 tkb289 is offline
Originally Posted by tcrist View Post
TKB,
Olander is the place where you can get almost anything but they are a bit more expensive.
You can get self clenching hardware from McMaster-Carr also but not as high of minimum purchase.
We buy quite a bit of Pem hardware and quite a bit of other types from many different sources.
Terry … You are most likely correct, Olander might be a bit more expensive. However, the past several times I have been at Olander, there was no minimum purchase amount for cash. I believe there is a $10 or so minimum if a credit card is used. I like that one can buy a small quantity of different sizes, because sometimes it's hard to know what will work and they almost always have what you need. Best to go with a list of what you want, and they can make suggestions as needed. Always good to shop around.
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
