Originally Posted by 428street
Stalled as I'm to afraid to do it myself...everything is cut out and ready but having second thoughts as seems like anyway I look at it I have one shot once I stick it on and I've been told that the summer heat is my friend...it isn't that warm up here yet...
Probably so. I assume this is one big piece of vinyl. Are you going to apply contact cement to just the center section first - apply the vinyl and smooth it out? Then do one side and then go back and do the other? I guess you can do it in as many increments as you feel comfortable with. That inside corner at the bottom step is probably one of the trickiest areas. If there is any tension in the vinyl when applied across it, it will tend to loosen up in a bubble.
