Old 04-11-2013, 04:53 PM
tcrist tcrist is offline
The header bolt pattern for the 302 & the 351 are the same but the deck height on the 351 is around 1" taller than the 302.
I believe the motor mount location is the same.
What this means is that if you install a 302 where the 351 was and use the 351 headers, the headers should be about 5/8" to 3/4" closer to the ground. That does not mean that you could not raise up the 302 to be higher in the frame. Do not know what else that might impact on an ERA though.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
