I have got you covered Gav.
I found these out behind teh shed, if your bores are all good we can slap another stock bottom end in it for you.
I will degrease them and blow them dry so they are ready to fit, I think even the rings are still pretty good.
Or if your bores are shagged, I pulled this out of an old ****ter a while back.
I will get the wiper sniper out first then hit it with degreaser, should be good to go as it is, as the car that it was in stopped due to a smash and roll over, not an engine failure, probably go back and get the gearbox too if you need that?
Cruising in 5th
