Well, Nick and I went to do a trial fitting with the Quicktime scattershield and Forte modified fork and slave bracket. Even though the Hi-Tech motor mounts are a little taller than the Shelby or Kirkham, which should have allowed for more clearance, the fork was still hitting the frame rail. I could probably nibble a little off the corner of the fork but it would still be really close and there would still be no way to mount the slave that low. Looks like I will be modifying the QT bellhousing unless anyone else has a better solution.
