Old 04-18-2013, 01:41 AM
ERA2076 ERA2076 is offline
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Default Roll Bar End Links
Bob - The front end links on my car seem long. The bar is at quite an angle relative to the lower control arm. I would like to run the ba, parallel to the lower control arm. I mocked it up and it leaves about 2 5/16 between the bar mount and arm mount when both are parallel to ground. I have a blown shock mounted with no spring and I can fully cycle it. The bar appears to articulate with no binding within the shock travel. I threw a mounted tire up there as a sanity check and it all looks good.
I want to run rod ends. It looks like it will work - compact, but doable.
Am I missing something?
Side note - I threw a front lower control arm on a CMM and ended up with a .96 motion ration. Got some leverage out there.
Very nice and thank you.
