04-24-2013, 09:07 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
I would guess that you could do some sanding with the DA. If you are an exponent with powered sanders you may be able to sculpt the body to eliminate some imperfections. If you're not an expert users you could end up an even bigger problem.
For perfection you'd have to use various boards and perhaps some custom shape sanding blocks too. It's a small car and withe the right grit papers and some elbow-grease you have it licked in a reasonable amount of time.
Don't forget the guide coat to expose the low areas.
Good luck, Arthur
