Old 04-26-2013, 06:17 AM
patrickt patrickt is offline
Originally Posted by wrench87 View Post
I am running a expansion tank, I am going to remove the alternator so i can get a better look. The funny thing is I can never see anything drip but when I take the car out there is a large wet spot spread out on the garage floor it is to the point that you cant tell it is antifreeze unless you wipe it and take a sniff?.
Fluorescent dye in the cooling system will show the origin of a coolant leak like that pretty quick. I had a trickle from the heater hose shutoff valve that required that to spot.
