Originally Posted by wrench87
I am running a expansion tank, I am going to remove the alternator so i can get a better look. The funny thing is I can never see anything drip but when I take the car out there is a large wet spot spread out on the garage floor it is to the point that you cant tell it is antifreeze unless you wipe it and take a sniff?.
well if it lays down that much on the floor you should have no problem seeing the leak......i wouldn't take it apart just yet.....i would warm it up and shut it off to see the leak..... pull the wheel on that side so you can get under it to see with a good shop light.
