  #429 (permalink)
Old 04-28-2013, 01:31 PM
PDUB PDUB is offline
Glad to hear you are doing better!
A couple of thoughts on the brake lines... if you can't get close enough to the end to do the 180-degree bends, leave a little slack and bend it away from the fitting, then cut and reflair the end, or have a shop do the initial 180-degree bends and then take it from there. Should make life easier...
Did you slide the nut back away from the flair when you tried to bend it?
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
