  #430 (permalink)
Old 04-29-2013, 04:15 AM
Default Gald to hear your problems
767JOCKEY Doug for tight turns with brake lines, try this. Get the fitting to the end of the line. Need a set of vice grips and a socket. You can clip on the fitting and bend the line around the socket for a 180 bend. Smaller the socket tighter the bend. I think your limit is about 1/2". If you have a problem with the 180 degree bent, do a 90 with a circle of 360 and another 90. This will not look pretty but work fine, going on 16 years. The new brake lines are softer that the stainless steel ones too. Rick L. Ps gald to hear you grumping
