Old 04-30-2013, 08:40 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
I like the Shell Valley cars. Shell Valley changed bodies and re-did their frames some years ago. They are a supplier of parts for several other cobra manufacturers. The current car has an adjustable four link in the rear with a 9" axle. They like several others use the Mustang II front spindles with GM metric brakes that can be upgraded. If that's a newer car built within the last seven years, and built well, it could be a pretty good deal. Figure the complete kit now without engine trans, drive shaft, wheels and tires and paint is about 20K.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
