Old 05-01-2013, 01:05 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Cobra Make & Engine: 1989 KCC from South Africa Right Hand Drive
The inner tierod ball joint..needs to be in line with the pivot point of the lower control arm ............l
and if the rack is two inches.(just picked a number) for instance , higher then the control arm then the spindle should
position the outer tierod ball joint two inches above the control arm, lower spindle ball joint
and so on........
.........so if your spindle is ok ,just remount the rack accordingly....the length of the steering arm on the spindle will also alter your steering ratio or effort required ..........so many variables......
