  #37 (permalink)
Old 05-01-2013, 11:14 AM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default Blinker fluid
Originally Posted by tkb289 View Post
Chas,
If you wind up needing a new battery, some are made with a vent spout that you can connect to a drain hose. Should this happen again, the water / acid goes on the ground and not on the car.
Blas is right, get it tested. I do like the blinker fluid theory
Years ago, it was "muffler bearings" and nobody got that either. The sea monkey thing is priceless.
There were no atheists in the foxholes.
