Old 05-04-2013, 07:30 PM
Tom Howland Tom Howland is offline
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
I did a coolant pressure test before I took the head off. The radiator has some small leaks. So really the larger job is fixing those or getting a new radiator. The tubes are epoxied to the side headers. I've fixed 2 leaks before but don't know if these are the same.
I will use the same head gasket. The failure was my fault in not keeping the coolant toped up. The puke tank had coolant in it. I should have checked the radiator cap on the overflow tank.
Tom
