Old 05-04-2013, 09:38 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Default Clutch set up, throwout bearing?
I currently have a Mcleod hyd throwout bearing installed. It is threaded for adjustment (instead of the shims) so it can be adjusted through the bell housing instead of dropping the trans.
That is not my question though....does anybody with a big block in their CR LTD. have an external slave cylinder and a fork that operates the throwout bearing? Obviously not the same throwout bearing I currently have. I am wondering if there is enough room to squeeze one in. If so I may switch it over.
Thanks,
John
