Old 05-04-2013, 08:48 PM
tcrist tcrist is offline
John,
I think that DV set one up on Capteddies old CR. That is a CRII but I believe the same as a CR LTD.
That being said, I do know that it is possible in a CR LTD. There is enough room there. I was going to do that but the $ at the time just did not make it feasable.
You already have 50% of what you need. All that you need now is some hose (and maybe you already have enough) a slave cylinder,a new throwout bearing, a clutch fork and a clutch fork piviot ball.
Your bell housing should already have a provision for a clutch fork pivot ball, but you will need to check if it is on the passenger or drivers side.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
