Old 05-05-2013, 01:49 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Success!
Replaced the alternator and the voltage regulator and the ammeter no longer runs up to 45 Amps, and the voltage is rock-solid at about 14.5V.
There was a big sticker on the alternator warning that the voltage regulator should be changed at the same time. The new alternator is a NAPA/Motorcraft unit, made in the USA.
In regard to the resistance between the I and the F terminals of the voltage regulator needing to be between 0 and 10 Ohms: I'm not buying it. I read it in the article on the web, but when I tested my brand new voltage regulator, it wasn't an open circuit but it was about 10 MOhms. However, the VR and Alt work fine.
I think I'll go for a test drive!
DD
Dangerous Doug
"You're kidding, right?"
