Which Roller Rockers?
I am in the process of gathering parts to build a 496 Tunnelport engine. I have a set of Dove aluminum heads and I don't want to use T&D rockers because I don't want to machine these heads for obvious reasons (leaks)
I want to use Harland Sharp rockers. Which one should I use, the bushed ones
[url=http://www.harlandsharp.com/fe_ford.htm] Bushed
or the needlebearing ones
[url=http://www.harlandsharp.com/ford_nb.htm] Needlebearing
This will be used primarily for a street car with limited track use.
Also will I have problems using head studs with these from clearance with the endstands?
Cobrarich
