It sounds like your timing is off because of the backfire issue. I have found that not all timing lights are accurate. If you have a buddy who also has a timming light double check with his. I've beat myself silly with the same problem you are describing.
If that is not the the problem then I would go to the radiator. Have it rebuilt with a thicker core or get an aluminum replacement.
Hyde D. Baker
