SGR, couple of questions for you...
When mounting your body, is the bottom front of your firewall pushed up against the car frame or is there a gap there?
Was the firewall pushed back against the cowl when you mounted the firewall?
Did you use the existing mounting holes from the cowl bar or did you tap new ones?
From my understanding, you use the factory pre-drilled and tapped holes for the cowl bar. Do not move it.
This resulted in mine having a 1/2 to 1 inch gap between the bottom front of the firewall and the frame.
