Old 05-20-2013, 11:11 AM
DanEC's Avatar
DanEC DanEC is offline
The sway bars wouldn't do anything to deflect the lower control arm forward or backward in turns due to the links and the rigedity of the a-arm bushings. Must be something else. What diameter tires are you using? I'm running slightly oversize tires on the front of mine and I had to shave a little off the driver side wheel well opening down at the bottom to clear.
