Ratsnake, I'm using the same monoleaf spring from vettebrakes that is with the newer front end on the car now. It is common knowledge that the earlier front suspension (84 to 87) works best with the E-M kit, but I had access to the later one when I built the car. I thought it would be just a matter of changing one or more componets to go to the earlier front but found that nothing is interchangeable cept the rack and maybe the swaybar. The earlier front does use single piston calipers, I guess this could be concidered a downgrade.
