The medium strength 3M from Track, Pep Boys, etc., will work fine. Spray both sides, let dry tack free, then stick. Now, for dashboards, there's one more step. Where the vinyl folds around the back of the dash, use DAP or Weldwood contact adhesive (Hardware store, Home Depot, Lowes). It's used for laminates and kitchen countertops. This stufff will hold the overlap in place, wheras, the 3M will not. If you decide to get fancy with a veneer (constantines.com), put the veneer over plywood with the Weldwood. Use screws, under the veneer, to attach the inlay through the dash. Cutout the foam backing under the vinyl dash for the inlay. Really looks plush.
