We've been making steady progress over the past couple of weeks, and the kids have helped me with almost everything. Since my last post, we've pulled the foot boxes (required removing the pedals and windshield) and floors, and then bonded and riveted them in permanently and reinstalled the pedals. We also installed some AWG-10 speaker wire on each side, and AWG-4 power wire on one side in case I want a stereo with an amp in the trunk and speakers in the foot boxes at a later point. I tied the wires up on the side of each foot box, and then riveted and bonded the aluminum panels under the doors. Last, we removed the firewall and bonded and riveted it back in. As you can see in some of the photos, I used Pemnuts wherever possible (floorboards, where the center tunnel will attach, and the center panel under the dash that connects the foot boxes).
I know a lot of people say you don't need Dynamat on the floors, etc. But after installing these panels they are like drums and will vibrate, even with carpet. It seems like a safe bet to install Dynamat on the floors, footboxes, and panels ahead of the rear wheels.
Next we will remove and install the panels in the rear footwells and trunk, which will require removing the roll bar. For anyone that has done this step before, did you drop the gas tank before drilling the panels in the trunk? The panels are fairly close and I think I could drill the holes without damaging the gas tank, but I may drop it just to be safe.
Also, should I leave the windshield off until I install the engine, or is it all right to reinstall it at this point?
Untitled by
Lippy111, on Flickr
Untitled by
Lippy111, on Flickr
Untitled by
Lippy111, on Flickr
Untitled by
Lippy111, on Flickr
