Old 05-31-2013, 02:57 AM
Danr55's Avatar
Danr55 Danr55 is offline
Chance are if you are using anything at .032 dia. or above, the wire is so stiff that it doesn't matter which way they are wired. I've twisted a lot of safety wire on a lot of airplanes and it's usually so stiff that you can't turn the nut even if you wire it backward.
Dan in Arizona
CCX3209
