Old 05-31-2013, 01:00 PM
Mr Jody Mr Jody is offline
Default Safety Wire Direction
Originally Posted by my427cobra View Post
So if I understand Bob's posted instructions, the safety wire is in tension, holding the spinner tight - right?
Different from previous methods posted which had the safety wire on the other side of the spinner, which when the safety wire went "loose" it was an indication the spinner was coming loose.
Just asking.
Greg
Yes. Think of it as if you tied the safety wire on the spinner, and then used the wire to pull the spinner around to tighten it. And then when tightened, you used the safety wire like a bungie cord to hold the spinner in place.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
