Old 05-31-2013, 10:49 PM
jhv48 jhv48 is offline
You say that all plugs are firing, but Then you say that #5,6,7 cylinders are not getting any spark from the distributor? If you pull the wires from those cylinders while the engine is running, can you touch them to the block and get a spark?
If the wires and plugs are good, it has to be a faulty rotor or cap. Try swapping out the distributor with the one you replaced.
Got to be spark related. Work back from the plug to the dizzy.
Jim
