  #53 (permalink)
Old 06-03-2013, 07:45 AM
patrickt patrickt is offline
Originally Posted by kevins2 View Post
That's what I was hoping, but wasn't sure. I could just hook up the slave cylinder and temporarily tie strap it to the chassis so I can bleed the brakes.
Thanks.
Kevin
Naaah, just put a little plug in the end of the clutch line so fluid doesn't leak out. Sooner or later you're bound to accidentally push the clutch pedal and if you don't have the hydraulics hooked up to it you won't squirt the slave apart when you do.
