I finished the trunk panels, and everything went great. There are some corners in the aluminum where you can see light (they are installed tightly, that's just the design) so I plan to seal some of the corners/joints with aluminum-colored sealer I found at McMaster-Carr. I think I'm officially addicted to McMaster-Carr, BTW.
One small bump in the road - I will install seat heaters and realized after I installed the aluminum interior panels under the doors that I didn't run the seat heater wires under the panels. So I either have to: (1) remove those panels and install the wires underneath, or (2) run the wires alongside, under the carpet. I think I'm going to remove the panels, which involves removing and reinstalling a bunch of rivets and some structural sealing glaze. I just want to be very careful that I don't enlarge the rivet holes so I ordered a punch that is meant to drive out the mandrel stubs (also from McMaster), and then I can carefully drill out the aluminum rivet bodies. Any thoughts or tips would be appreciated.
