Old 06-11-2013, 12:34 AM
Tarrensmith Tarrensmith is offline
Cobra Make, Engine: Shamrock Cobra - Chev 350
Originally Posted by RideUS60 View Post
Do you know if they used a Jag clutch master cylinder along with the front and rear ends?
Good luck with your build, Dave
Dave, great to hear you are giving life to a Shamrock! Shamrock built many cars for local and export to the rest of the world and yes there are still quite a few driving around Cape Town especially.
Regarding the clutch master - I'd assume you would use the Jag master as the aluminuim casting housing the break pedal also houses the clutch pedal and assembly. You would need to match the piston diameters so it corresponds to your clutch.
Check out my build blog on talk@cobraregistry.
Post some pics so we can all see!
Tarren.
