Old 06-11-2013, 05:57 PM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
Dan,
I'm just going to leave it polished. My engine has a few pops of polished bling, namely the Paxtons and carb hats, so it'll match ok.
roadrod,
Did your steel one work fine and your aluminum vapor lock? I was considering using extended fittings from the carb inlets and just sort of building a fuel 'log' out of T-fittings, elbows and braided line. Also, my fuel is fed from an electric pump that's basically plumbed to the firewall. I think that would reduce some vapor lock issue. No VL to date but have had heat soak at the gas station.
rodneym
