Old 03-17-2002, 03:56 PM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
Default Changing from MII column....Ignition questions..
So I am switching to a push start button (no key) after I changed out the column for an original style type. So now the fun part...The wiring.
I don't know if all standard auto columns use a mechanical type ignition, but the MII column has a little bar that pushes into a electrical box thingy as you turn the key. Anyone know what each of the wires are for that box? It would make life easier for me if I knew what each of them were before I go playing with wires.
Thanks for any help.
