Old 03-17-2002, 03:59 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
Depending on your seat height---In my car I ran a crossmember thru the trunk area from side to side, bolted it to the rear bulkhead and attached the belts there. After getting it exactly where I wanted it, i ran triangulation to the main frame rails and welded it all together, than hid it with aluminum panelling. It is important to remember that the belt should pull back and slightly down, so this may not work for you if your seat position is too high. There was a very good tech discussion on this topic not long ago...reccd you do a search on seatbelts...good luck, and be safe!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
