Thread: T-5 ?
Old 06-16-2013, 05:29 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Kenny,
I ran a built TKO 500 and I used the electronic VDO gauges as the speedometer is easy to calibrate after a tire size change or gear change. The Hall Effect sending unit screwed right into the same hole as the mechanical gear unit would go in. I had a Neutral Safety Switch that was electric but I can't recall just where it was located on the transmission.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
