Old 06-18-2013, 07:14 AM
stephen low's Avatar
stephen low stephen low is offline
Mr Bigone I know the pedal ratio is fine as the previous set up with a T5 gearbox using a wire clutch operation worked a dream and with pedal pressure as I would have expected.
On advice from McLeods that the master sizing I have seems appropriate it seems clearly more likely that there is something amiss either with the slave sizing or in the operation somewhere related to fork and thrust bearing.
I clearly need to confirm the slave cylinder size and make a decision from there.
But cheers for the input anyway.
Not so Slowly
Slowy
slowy
