Old 06-20-2013, 05:55 AM
sideshow sideshow is offline
I found this info on a 4 spd btr trans
I thought they had more solenoids but looks like only 2 solenoids so similar to Toyota
which is easy to make something using afew relays the only problem would be inhibitor
because on the fords they are a resistor type signal so not good
ive got some Toyota tip tronic units which are for two solenoids aswell but slightly different to the ford ones
if I knew abit more about this type of electronics I recon I could get these to work
all that is required is control over the S1 and S2 solenoids.
1st - S1/S2
2nd - S2
3rd - no power to either solenoid
4th - S1
my website
www.sideshowsperformancewiring.com.au
