Old 06-20-2013, 09:42 PM
wemooz wemooz is offline
Cobra Make, Engine: ERA 290, 428CJ
Default Clutch adjustment
There have been many questions and answers about clutch problems and I am just the latest one. I have a 428CJ with a Richmond gear 5 speed in my ERA 290 together with the regular ERA master and slave cylinder setup. When my car is cold, it shifts well. When it gets hot, it shifts with difficulty. When it gets very hot, it cannot be shifted into any gear unless the engine is stopped. The problem seems almost clearly that there is insufficient clearance between the flywheel and the driven clutch disc. I need to correct this, but I simply hate laying under the car, so I want to get the best advice before I start to get my hands dirty and do things that do not work. If it is a case of bleeding the hydraulic cylinders, I need to know if the front end should be higher than the rear or vice versa. If it might be something else, I need to know what to check so that I have the right tools with me under the car. Any and all advice will be very gratefully appreciated.
