Old 06-24-2013, 07:03 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Could you tell us what happened. Usually if cam lube is used on the lobes and high ZDDP break in oil, and then run the engine at 2000-2500 rpms varying the speed for about 25 minutes you don't have problems. That's got to be frustrating.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
